Series 2 Idle Jets
Series 2 Idle Jets
I have a 1971 Fulvia 1.3s with Solex 35 carburetors and one of the idle jets needs to be replaced. The jet is marked with a “41.” As I understand, the original size is 47. Does anyone know what size should be fitted to the carburetors?
Re: Series 2 Idle Jets
It is likely that what you read as 41 is in fact 47. Often numbers are poorly stamped. To confirm the jet size for your carb I will have to check the factory book, something I will do possibly tomorrw.
I confirm that the main jet is 120 and the idle jet is 47,
