Rubber Spring Block
maurice.lanciste
Rubber Spring Block
Messaggio da leggere da maurice.lanciste »
Hello!
For the Flavia Coupé Pininfarina 1963. Type 815330.
What is the standard height of the leaf spring end buffer of the front suspension ? (Height of the rubber part).
Thank you
Maurice
grifo63
Re: Rubber Spring Block
Hi Maurice, standard height is 90mm, when mounted and under load becomes 60..70mm.
maurice.lanciste
Thank you very much.
Torna a “Flavia e "2000"”
