S1 coupe heater unit
mikeg
Unread post by mikeg »
Looking at possibly removing my S1 coupe heater unit assembly for a refurb etc.
Is it possible to just close the heater cock and also the bleed cock (near the horns on the subframe) before removing the matrix hoses?
Or do I need to fully drain the coolant from the whole system?
thanks,
Mike
S1 Rallye 1,3
marnix
Re: S1 coupe heater unit
Unread post by marnix »
you best drain the coolant... not so, difficult. even then it will be a bit messy..
Huib
Site Admin
Unread post by Huib »
And blow compressed air into the hose going to the matrix to move as much coolant as possible to the drain.
Return to “65 Fulvia”
