However i am not able to get it to work again. I have tried replacing the fuse under the wheel, with the little frost / ac logo on it, as that usually is has been the cause of this issue prior. It did not work though.
Are there any other fuses that might cause something like this? Might it be the blower motor and how do i get to it to check it out? Is there a resistor somewhere that might have gone bad?
Please help, a problem like this makes the car almost undrivable, as it is impossible to get rid of the fog.
Thank you!
