Fulvia Zagato Sport 1600 window motor brackets
Huib
Site Admin
Unread post by Huib »
Hi guys
We are assembling a Zagato 1600. We have two identical mounting plates for the electric window motor. See picture. Either one mounts very well in the RH door. Putting them in the left hand door results in an awkward 45 degree position and requires removing some steel from a member inside the door. That steel was removed suggesting that that bracket was in the door before.
Does anybody have experience with the Zagato 1600 doors?
Are the original mounting plates identical or are there right hand and a left hand versions?
FL30
Re: Fulvia Zagato Sport 1600 window motor brackets
Unread post by FL30 »
Huib,
tavola 77B of the spare parts catalogue states different parts for rhd and lft (item 31)
Hubert
Hubert
Huib
Site Admin
Zoom in on the picture until you can read the numbers. Are they different or are they not different? I am confused.
FL30
It is #31, the three lines point at the wire rope and the main plate, described as complete assembly. The picture shows rhd side, the mounting plate is mirrored for left side. The table names two Fispa numbers and dfferenciates rhd and lft
Hubert
Huib
Site Admin
Thanks Hubert.
Next question.
Who can help me get the bracket for the lh side?
Return to “65 Fulvia”
