fulvia carburators problems
ph21
Unread post by ph21 »
Hi,
I'm waking up a 1300s fulvia s2 from 1972 i presume, bought from second hand .
seems to be a very good unit but the carburators makes me now nightmares.(solex c35 phh 19 rear and 16front)
I completely dismantled them and cleaned all parts, the old petrol had glued inside.
I cleaned the main bodies in an ultrasonic machine, also the various jets.
The engine waked up, and I made the settings, idle petrol proportion and synchronisation;
The engine turns pretty well when in the garage, but when I drive the car, it don't want to overpass 3000 rpm.
Seems to be poor at 3000 and over. It's possible to overpass when activating the cold choke, or when pumping on the pedal to feed petrol throug the acceleration pump.
Due to this problem, I dismantled again for checking 8 or 10 times, but no real changes.
Thinking to be a faulty air intake , i dismantled today all the pipes but seem to be ok ; I also closed the vacuum hose for the brake servo; the problem still remain.
I discover also today some cracks along the central choke tubes attached to the cover, and welded them ; but I think those tubes can only act when the choke is activated .I didnot tested the car after... I will see tomorow but without any hope.
Last precision, I progressively rose up the petrol level in the chambers; Its now about 20mm as precised in the tecnical datas.
some ideas?
LanciaFin
Re: fulvia carburators problems
Unread post by LanciaFin »
Hi,
This can be a problem with ignition as well. I'd check that side next. Maybe with another coil first?
ph21
Hi, LanciaFin,
may be, may be you are right...
But a good new today, this post will not be very large, because after some hours of work , the problem is now solved.
First test by this morning , no much progress.
I dismantled all the carbs again and decided this time to clean with a lot of care the only circuit I did not dismantled before the ultrasonic bath;
This circuit is called by a strange term in french "circuit de désiphonnage ", may be " siphon off circuit" or "drain circuit in english? This circuit is a pass beetween the main petrol vat and the pump vat . Under two plugs there is a weight pushing on a ball . And various air circuits inside and around.
after reassembling the carbs and fitted onto the car, I also took care to verificate the ignition . I found the excentric system into the ignitor with some play on the weights and also bad moves due to old grease, dust and surface rust. So may be the excentric advance was not optimal.I renewed those parts.
so the problem was due to a bad function of the siphon off circuit ,or only bad ignition , difficult to say ; but for those waking up, old solexes 35 with decades of glued old petrol inside, dont hesitate to take care to this circuit...
Now I'm happy finishing to solve a problem wich occupied me the three last weeks...
Hope this wiil help ,and thanks to LanciaFin. :mrgreen:
Huib
Site Admin
Unread post by Huib »
Bonjour,
The steel ball with the weight on top is a valve between the acceleration pump and the acceleration jet. The acceleration pump is the principle of a bellows. The valve at the input is a steel ball hidden in the seperation between float chamber and pump (thus the bottom of the float chamber). You can't see it. To check if the ball moves freely I shake that part nex to my ear and listen.
At the output of the bellows are the two valves as you describe. Each barrel of the carb has its acceleration jet and each acceleration jet has its valve.
You may want to check that the acceleration jets work. Look into the barrel and flip the throttle. You should see a squirt from the jet at the top of the barrel near the butterfly valve.
LanciaFin
Ok, I thought the carburettor had been opened everywhere already, so the ignition seemed quite obvious culprit. But anyway, it runs now fine, so nothing else matters. :)
ThomasW
Unread post by ThomasW »
Hello,
I would be interested in finding out where to get new parts for the distributor.
For my Fulvia I am still searching for the sweet spot in setting up the carbs and ignition. The excentric system on the ignitor, as you describe is a culprit as well on my car.
The regular adresses for parts do not list any of the Fulvia distributor parts, where did you get yours?
Regards, Thomas
Huib
Site Admin
Ignition
I sell the electronic version on this website.
http://www.viva-lancia.com/specials/ignition/index.htm
Pictures are of the previous version. The version I have in stock is the latest. Spark plug cables are now black.
ThomasW
Thanks, but I want to stick with mechanical distribution. Is it possible to revise these or get new parts for the centrifugal mechanism?
LanciaFin
At least for Flavia distributor i got all service parts using Fiat 1300/1500 and Marelli S102 as search term. The cap is different, but fits 100%. The availability of Flavia-specific cap is anyway quite scarce, and prices prohibitive.
Of course it is possible to revise these, as they are designed to be serviced, unlike many more modern distributors. Getting the centrifugal mechanism correctly set up will probably need a variable drive for testing with different rpms.
BR,
Miika
Return to “65 Fulvia”
