Just making enquiry if anyone has a K&N Filter in their thema if so I am considering putting one in my '94 2lt 16v, I am looking for either your K&N filter reference or the lancia filter part number for cross reference.
Thanks,
John o Brien.
K&N Filter for thema
Lindsay
Re: K&N Filter for thema
Not sure John. I have one in my Kappa Coupe 20vt Coupe which i got from Germany. Take a look on ebay in the europe search. May well come across one there.
kassus
i use on my thema 16vt and didnt feel anything.
OEM are very good
regards
OEM are very good
regards
john o brien
i have found a similar make of K&N Filter at www.greenfilters.com which a cousin uses in his dedra and says it works fine, nice growl out of car as it picks up.
Thanks all for your help,
John O Brien.
P.S -Lindsay I have to agree with your earlier topic, that the kappa does have nicer lines than the thema.
John O Brien.
Lindsay
Hi John. Good luck with the filter. Actually, I don't think it made much difference to my Kappa but at least it is maintenance free for 50k miles!
Controversial about the K! I have since bought an LS turbo to join the Kappa. I think the Thema still holds its own, but the Kappa is so underrated. Once again, pity we dont have easier access to Kappas and the later models....
kassus
hi all. the engine will be more "noisy", specially if you are using aluminium dv (forge or similar) because its obvious, there is an air ratio imporvement. anyway the better of this filters is they are long life
regards
regards
Pierre
The K&N part no is 33-2593
I don't think they make them any more, maybe you are lucky with some old stock somewhere.
