Fulvia brakes
carloscasmiri
Fulvia brakes
Unread post by carloscasmiri »
Wanted to know if it's possible to change my fulvia coupe series 1 brakes with series 2 or 3.
Any help would be great.
Huib
Site Admin
Re: Fulvia brakes
Unread post by Huib »
Why would you? The S1 brakes are excellent when in order.
At the front you have an issue with the swivels. You need the S2 swivels. I am not sure about the upper suspension ball joints nor track rod ends. If you need the S2 track rod ends you also have to change the Pitman arms on steering box and idler box. And change the central track rod.
At the rear you have an issue with the hand brake The S1 has the pinchers operating on the disc. The S2 has a combined system at the rear. Disc for the foot brake. Drum for the hand brake. To be able to mount the drum brake you need an S2 rear axle and disc. I am not sure about the hub.
You need to put in the brake force limiter from the S2. You already have the axle. Just weld the hardware to mount it to the bottom of the car.
Often over looked is the different ratio between volumes of the chambers of the master brake cilinder. Because of the Super Duplex lay out the amounts of brake fluid each chamber has to pump is different. You need a S2 master brake cilinder. It has a diameter of 22 mm. So you also need a servo.
Don't under estimate the difference in brake fluid volume! Sometimes Fulvisti mount a non original master brake cilinder on their S2. Commercial people sell these too easily. I am not sure that the volumes of the chambers are suitable for Super Duplex. Lancia was rather unique with the Super Duplex system.
carloscasmiri
Re: Fulvia brakes
Hi Huib
Thanks for all the info looks like I have to reco the S1 brakes, the only reason I asked is that I have a S2 that I'm using for parts.
I'm located in Sydney Australia and always loved the Fulvia's coupe, I had a 1.6 HF many years ago when I lived in Italy.
Thanks for your help.
Carlos
Huib
Site Admin
Re: Fulvia brakes
That's what I would do. The parts are available now.
I would not sleeve the wheel brake cilinders, certainly not the ones at the front.. You would have to machine the cilinder walls before putting the bushes in. They then become sort of 2 1/4"cilinders which were actually available in the sixties but quickly discontinued as they cracked.
Charles
Re: Fulvia brakes
Unread post by Charles »
I have been reconditioning S1 brakes a few times but found the result never satisfactory and needing to recondition the brakes every two years in order to gain MOT. Usually the cilinders are far too pitted. So in the end I decided to bite the bullet and replace them with new cilinders supplied through this site. I'm super pleased with the results; very good and very reliable stopping power. I would advise anyone with a S1 Fulvia to do the same.
Charles
Lancia Fulvia Sport 1,3 1968
FIAT Sportspider 124 1969
Innocenti Cooper 1300 1973
Land Rover 88 Series II 1960
Alfa Romeo 159SW 2007
Return to “65 Fulvia”
