cooling my lancia thema turbo 16v 1994
michael hadass
Unread post by michael hadass »
hi !
i am intresting in a bigger intercooler and oil cooler anyone knows a good ones exept the forge integrale intercooler?
also does anyone knows a good shop that have forge intercoolers?
thanks
michael hadass
kassus
Re: cooling my lancia thema turbo 16v 1994
Unread post by kassus »
hi
i saw pics of two oil coolers, so it was on delta dragster :-) if you use good oil 10w 60 there no will be problems with temp and performace. about the intercooler, you can install a frontal mount as coupe´s users do. this is the best option, althought there are others interesting mods, like fit a delta oem unit (full aluminium without plastic tapets). this is not a direct fit so you must search for piping kits. you also can visit forge or ebay websites to look up for this big itc models
regards
thomabo
Unread post by thomabo »
Change your oil type/brand. Had problems with rising oil temp under hard climbing and turbo operation and switched to Mobile 1 and it all disappeared. For 3 years I basically "forgot" that I had an oil temp gauge. Switched back to cheaper Castrol due to leakage in a seal. Now the oil temperature thing is back.
To switch to full alu delta intercooler is a good idea since you will gain more power, but I doubt your engine will get any cooler :)
thomabo
Return to “51 Thema”
