Rear fuel pump
CD's with workshop manuals, parts book and other documentation New: electronic distributor
Konstantinos
Rear fuel pump
Unread post by Konstantinos »
Hi all.
I would like to know where I can find rear pump for flavia coupe 1,8 iniezione.
A guy told me that Porsche 924 uses the same pump.
Does anyone knows what the pressure should be?
Best regards
Konstantinos
flavia1800
Re: Rear fuel pump
Unread post by flavia1800 »
Hi Konstantinos,
these pumps are mostly made/marketed by Facet nowadays. They come in a range of fuel flow volumes and pressures, and are 12 or 24 volts. Look on the Facet website for details: http://www.facet-purolator.com/gold-flo.php
Kind regards
Gunther
Bert Ewalds
Re: Rear fuel pump
Unread post by Bert Ewalds »
Fuel pump on a Flavia 1.8 Inizione Coupe does not sit in the rear, but originally is located in the engine compartment.
Right hand side beneath the ignition coil. see picture.
And yes that gives some problems in hot climates with vapor lock etc.
operating pressure is between 1.1 an 1.5 Bar.
Peugeot owners (504 injection) typically use the pump Pierburg 7.21538.500
It sits at the lower end of the pressure range. (1.1 Bar)
You can also fit a pump with a higher pressure and a pressure regulator.
best regards,
Bert
fuelpump location.jpg (195.13 KiB) Viewed 1991 times
Return to “68 Flavia, Lancia 2000”
