Hello All,
Does anyone know if shivering appearing when the clutch is engaged means the clutch shall be replaced or there is another cause for it?
Thanks,
Eyal.
Shivering Problem
Re: Shivering Problem
Unread post by Paddy »
Hi,
The clutch is a pull system and some of them seem to have that problem. It is not necessarly a worn clutch. Check hydraulic mounts, the rubber buffers in the top engine drag link and backlash in the gear/drive system also.
Paddy
Paddy
