Oil cooler on Flavia S2
CD's with workshop manuals, parts book and other documentation New: electronic distributor
LanciaFin
Unread post by LanciaFin »
Hello,
Is the oil cooler somehow directly bolted to the radiator, or is there some kind of bracket between them? I'm of course talking about the upper attachment point. There are brackets in cooler and in radiator, but they are 90 degrees off each other, so I cannot imagine any sensible way to bolt them together with just one bolt, as the parts catalogue insists.
The cooler has been bought separately (one didn't come with the car), but it is supposed to be from a S2 Flavia, and it also looks like in the picture of parts catalogue.
Of course, a close picture could help a lot. :)-D
Regards,
-Miika
Pierre VALLADE
Re: Oil cooler on Flavia S2
Unread post by Pierre VALLADE »
Hi,
I am not the first owner of the car, so not fully sure that it's the genuine link between the two coolers. But however probably..
On the last picture, at bottom, the steering oïl pump.
Flavia sedan S2 MilleOtto 1968.
More pictures on request.
Hope this help.
Best regards,
Pierre
Aurelia B21, Flaminia GTL, Flavia Milleotto, 2000 coupé,
Beta HPE, Beta Trevi VX, Prisma 1.6, Kappa coupés 2.4 & T20, Thesis V6 3.0
LanciaFin
Thank you Pierre!
That looks like a home-brew method; The bracket on the cooler seems to have been twisted to match the radiator. Unless something else comes up, I'll probably do the same.
Regards,
-Miika
LanciaFin
Well... No wonder it was difficult to figure out, how to install this thing. My cooler is probably from Flavia 815. I realized it after trying to install it and yet once again checking Pierre's picture. No way it would ever fit as is:
https://1drv.ms/i/s!AiQwQq0Hz81Sg8EBpdFhidi4IrrMkw
The picture in Flavia 819 parts book is not correct. So, time to find a correct cooler, I'm open for offers.
Regards,
-Miika
grifo63
Unread post by grifo63 »
Ciao LanciaFin, from a quick search on internet I find the following:
http://www.kijiji.it/annunci/ricambi-au ... 90227139#4
It is claimed to fit for the "2000", I wander if can be the same for your 1800 but probabily yes; of course I reccomend to check it on the spare parts catalougue .
Just as a comment: it appears different from the one from 1st series not only for the upper bracket but also for the oil pipe connectors, inverted and in a lower position, and for the lower rubber dumpen bracket shifted from the radiator main axis .
Pierre VALLADE
The oïl cooler on the net (grifo63) looks like the one of my car. (see pictures attached). Including oïl pipes.
Looking at the 819 parts book (tav 22A ) the oïl cooler is different, but this page is a "change" of 02/70. My Flavia Milleotto is 1968.
LanciaFin
Thank you Grifo!
With the price on the ad, I'll probably choose to modificate my existing unit. The pictures in the ad are a great help with that, to get an original look. This is not a top priority issue anyway, because I think that there will be no overheating problems during running in, especially in typical Finnish weather, if the oil hoses are simply connected together. Or, I can substitute a Fiat Uno Turbo-unit I happen have in my parts bin, until a correct [looking] unit is available.
The engine has not been started yet anyway. Maybe (hopefully) before the end of this year.
regards,
-Miika
grifo63
I've never try the Finnish winter weather but I do suppose it should be quite cool; perhaps, before to optimize the of oil radiator behaviuors, is better to check if the water thermostat will close well :)
I'm awating for good news of your first run!
gcarenini
Unread post by gcarenini »
Hello Mirka,
I have one unit from S2 mille ottobre. If interested I can send you detailed pictures ora quotes.
Giovanni
LanciaFin
Thanks Giovanni, I dropped an email.
Return to “68 Flavia, Lancia 2000”
