I mounted the igniter 123 on my new engine with the standard coil (3ohm) and silicone / carbon wire.
I had to remove and replace the classic igniter because I had too much cold start problems and even failures wheelchair until the engine is hot. With conventional igniter, I have no problem.
With the special coil (beru) sold on the site, can I resolve the problem? Should I also had to change the wires? The manual states that the assembly with a standard coil is possible then?
problem when mounting an igniter 123.
