Headlight
Voikkari
Headlight
Unread post by Voikkari »
Hi!
I have seen in some service manual a picture that shows how headlight can be easily removed for Light bulb change. How is this actually done?
Voikkari
BE3yH
Re: Headlight
Unread post by BE3yH »
Did you find answer for your question?
Max
JT McClean
Re: Headlight
Unread post by JT McClean »
I have a strong feeling that this fellow Thesisti comes from Finland, so please check Finnish Fiatforum from here: Kokemuksia Thesiksestä
BR,
Jari
__________________________________
Lancia Thesis 3.0 V6 Emblema 2003
Plymouth Belvedere 2D HT 1958 "Christine"
VW 1200 1965
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn!
Isola
Re: Headlight
Unread post by Isola »
See the attached PDF file. The "special wrench" mentioned is an ordinary 5 mm socket, although you may need a universal joint (a swivel adapter). It's recommended to use a six-corner socket. I got a cheap 12-corner one stuck at the locking rod. Not that bad actually: the socket stays there and it is easier to locate than the hexagonal rod end rather deep inside the fender.
thesis light cluster en.pdf
(122.39 KiB) Downloaded 106 times
Return to “40 Thesis”
