What's the new in the firmware version 3.0.2.0 for Loudlink Bluetooth Handsfree Car Kit and Ogg Vorbis MP3 AAC WMA FLAC WAV player for Lancia THESIS (LLK-UNIBLUE models)?
improved CD Changer emulation
improved fast fwd / rwd function
modified Disk layout
if SD card INSERTED
Disk1 : access to folders on SD card (track1 means folder1, track2 means folder2, etc.)
Disk2 : play files within selected folder on Disk1
Disk3 : Bluetooth music playback / call manager (track1 means reject / hangup calls, track3 means answer calls)
Disk4 : Bluetooth setup (track2 means disconnect current connection, track4 initiate pairings)
Disk5 : hands free microphone volume (track1 - track8)
Disk6 - Disk10 : same as Disk3
if SD card NOT INSERTED
Disk1 - Disk3 : Bluetooth music playback / call manager (track1 means reject / hangup calls, track3 means answer calls)
restore playback position from SD card when switch between SD card / Bluetooth
answer / reject / hangup Bluetooth calls during playback from SD card
automatically initiate Bluetooth connection after power-up
Loudlink Bluetooth / Mp3 / FLAC Car kit firmware update V3.0.2.0 for LLK-UNIBLUE
Arnold - Lancia Thesis 3.0 Emblema - Alfa Romeo Spider 2.0TS
http://www.loudlink.eu - Cd changer replacement solid state car MP3 players for Alfa Romeo, Fiat, Lancia, Maserati, Porsche
Re: Loudlink Bluetooth / Mp3 / FLAC Car kit firmware update V3.0.2.0 for LLK-UNIBLUE
Good to see you here Arnold, but my loudlink doesn't work like expected from the first day (about 6 months ago) and there is still no solution.. Tried everything, Firmware update, copying files manually or with Loudlink Explorer..
Maybe you can help me here..
This is the text on the loudlink Website:
CD1 - CD1
CD2 - CD2
CD3 - CD3
CD4 - CD4
CD5 - CD5
CD6 - AUX (cause I selected it in the Loudlink Explorer as AUX)
I used the newest Version of Loudlink Explorer to prepare the Card..
How can I get the functionality stated on the website?
In my Thesis with Loudlink LLK-LTHX it is like that:http://loudlink.eu/webshop/index.php?main_page=document_general_info&cPath=2&products_id=109 wrote: Firmware version 1.1.0 for Loudlink LLK-LTHX models.
What's the new in the firmware version 1.1.0?
Subfolder capabilites, from now Loudlink can handle cca. 10000 Songs.
(99 Albums x 99 Track)
Simply copy Albums to the SD card!
CD1 - select Album
CD2 - CD5 select Mp3s within selected Album
CD6 - select AUX
Minor bugfixes.
CD1 - CD1
CD2 - CD2
CD3 - CD3
CD4 - CD4
CD5 - CD5
Are you sure firmware updated and up to date?
I recommend to format SD card , which size <=2Gybte
Copy unzipped fw.bin file to the empty card
Wait while LED on loudlink goes off. Sometimes takes minutes, depends on Thesis when go to stand-by.
Insert SD card with firmware.
And after around 20seconds blinking goes off again.
If firmware is up to date, goes off immediately.
Copy few folders mp3 inside to SD card.
Change radio to CDC, and switch to CD1.
track1 means 1st folder on SD
track2 means 2nd folder on SD
etc
When folder selected switch radio to CD2, and whole folder will be played.
Please let me know the result!
etc
Hey Arnold,
Firmware update finally successful!
I switched the key off and even locked the car but still had to wait around 5 minutes until the red led had gone off (no led activity at all). Then I inserted the SD (128MB and only fw.bin on it) and update process worked for about 5 seconds.. Changed SD with 32GB SDHC and it works like you described!
After all great device but you should update the description at:
http://loudlink.eu/webshop/index.php?ma ... cts_id=109
Would have saved me a lot of Trouble
Best Regards
Stefan
Best Regards
Stefan
Lancia THESIS
What's the new in the firmware version 3.0.2.3?
SIRI and other voice assistant activation with fast rewind button.
In my iPhone 6 plus iOS 9 no activation for SIRI.
