Hi..
Is there anyone that have some good advices, about how i can get more bhp out of my 2.8 V6 engine?
I know that it is possible to fit a bi-turbo kit, just like the one in Renault Alpine V6 (240hp) with the same engine as in Thema. But i think that will be to expensive..
Ciao, norwegian Lancia-fan
Forza Lancia!!!!
How to get more power in a 1987 Thema 2.8 V6
markus
Re: How to get more power in a 1987 Thema 2.8 V6
Hallo
You must have an Citroen XM latest model or Pougot engine with 200PS.But the Engine ist not the same.
the haeds are different. earlierer haeds (2valves) has no Balancerscaft into one Haed (Behind).lancia makes also modification to the Cranksshaft.The alpine engine is an turbo engine.For you is better than you have a crashcar(Citroen-Pougot)you fitted the coplet engine into your lancia.after the mecanical operation you must conneting the electronic ecu with modifcations.
the better engine is the 3 series 3,0 v6 from alfa romeo. i have a complet engine/gear box and electronic from a crash car.when you cant fitted this i can make this operations for you.you can call to my mobil
in germany 0049-170-5588114
my name is markus
sorry for my not complet english
my name is markus
Antoine
hi lancia -fan
if you want 14 hp and 2.1 mkg for your car , no more expensive ( I think 400 euros) with electronique box
I give you this adress www.powersystem.fr you can get a few little hp if you change your air filter for a direct air filter
have more fun with your lancia
ciao,ciao
ciao,ciao
Tamula
Hello, Lancia fan,
I also have Lancia Thema v6 2.8 1987 and now I'm getting to replace my v6 engine with alfa romeo v6 turbo engine, you may replace your engine with 92'or younger Lancia Thema v6 engine which was developed from alfa's v6 engine but producing less power (about 176HP), but you think more because yours v6 servis is cheaper than alfas, citroen or peugeot engines and maybe it is better to replace air filter in sport air filter, change your mufler, distribution shafts, make more presure in cylindres (from 8pa to 12) and other more details. You may count what is cheaper to you. Once I saw riped up 1985 2.8 v6 engine that covered more than 300000 km and its condition was perfect there was no worn out on cylinders they looked like they was yesterday made, it needed to replace only valve glands. Power is enought to leave Citroen and Peugeot v6 far in the end it's a big pleasure knowing that these engines producing more than 170hp and yours "poor" Lancia got only 150hp.
Good luck in modifying your Lancia. Let me know about what you did to make your Thema stronger and faster.
Lancisti from Norway
Hi..
Thank you all for replying on my message, I am going to work on it these winter, so that I next spring can take out of the garage a fullblooded "racingmachine". I will try to keep you uppdated.
