The seatbelt warning light in my Thema Turbo LX 1994 is always on. Does anyone know the most common reason for this?
Thanks
Villads
Seatbelt warning light
Pol
Re: Seatbelt warning light
Unread post by Pol »
I've had the same problem, turned out to be the swhitch in the seatbelt slot (or whatever you call that thing where you click the belt in). I was trying to figure out how it worked and tried to open it, and while poking in it with a small screwdriver, the light started to go on and off, since then it worked again. I guess that was just plain luck, it was the easiest repair I've ever done on that car!
Greetings,
Pol
Greetings,
Pol
