My V6 Thema runs beautifully most of the time but occasionally refuses to start when its been running for awhile. If I leave it for an hour to cool down it starts perfectly. I'm told its most likely to be a problem with the pressure relief valve in the fuel pump - can anyone confirm this or do you have other suggestions?
Do these models idle roughly especially when cold?
My wife can't understand why I have to drive "a tempermental Italian Bitch" (her words) but once you have owned one Lancia you seem to want to have another
						V6 hot starting problem
				Daniel
Re: V6 hot starting problem
Hello Paul,
I had the same problem with my 1992 Thema V6 some time ago, but it occured only one time.
Some months later, the engine had very poor power if it was lukewarm
and also not full power if it was hot. If the car was cold (in the mornings), everything worked fine.
All the problems were caused by a rotten exhaust! Depending on the temperature, a metal sheet inside the exhaust moved and closed the exhaust partly.
Some malfunctions are very difficult to find on these cars. In my opinion, it is the only way to find a real Lancia specialist for repair and service.
Best regards from Germany
Daniel
Daniel
				Riccardo
Hi Guys,
I too have a 2.8 V6, I think they are getting extremely rare these days! Paul, do you live in the UK? If so, do you know of any experts which have knowledge of these cars? Its virtually impossible to find anyone in this country which does.
In response to your query regarding hot starting, my car has no problems at all with this (81k miles). I do, however, have a bit of a rough idle when the engine is just started. In the first 30 or 60 seconds when started from cold the idle fluctuates from 750 to 1200 rpm.
It would be great if any of you 2.8 owners out there could contact me as I would like to have as much knowledge as possible on these cars.
Best regards
Riccardo
Best regards
Riccardo
				Pertti Tapio Mäkelä
I have some good news, since there is a new association for PRV V6 -engined cars, the engine that is found also in your Lancia Thema!
Please feel welcome to join the Douvrin PRV Six-Engine Association simply by e-mailing me.
Check out also the Associations websites (although there is no separate section for Lancia Thema V6 yet):
http://douvrinprv.com
http://members.fortunecity.com/perttim/ ... ult30file/
Yours,
Mr. Pertti Mäkelä
Turku, Finland
Founder of the Douvrin PRV Six-Engine Association
Yours,
Mr. Pertti Mäkelä
Turku, Finland
				rex
Hello Pertti,
Greetings from Turku. I have just bought a dedra and seems to be having problems with the radiator. It gets too hot (90 degrees centigrade in about 10/15minuites) could you be of help to me? please kindly advice.
Thank you
Rex
(Turku- Finland)
040-7071420
Thank you
Rex
(Turku- Finland)
040-7071420
				Christian
I talked to an fiat dealer and they had the same problem with Croma. The problem was caused by a broken rpm/tdc sensor.
Christian
						Christian
