Can anyone tell me the proper procedure to check transmission fluid level on a 1990 Thema with automatic transmission?  The dipstick has high and low level markings for +40 and +80 degree temperatures.  My question is, do you leave the car running and in park or neutral after bringing up to temperature; do you cycle the shifter through the gears and check level immediately after: or do you shut engine off after warming up and then check?
I appreciate any info on this matter.
Thanks,
Mike Schieber
						Correct Transmission Fluid Level check
				renoir
Re: Correct Transmission Fluid Level check
Unread post by renoir »
Hi,
The operating manual says there are two ways to check the oil level.
1) Cold oil (40°):
Let the engine run for one minute in neutral (without driving), shut it down and check the level using the "cold-oil" markings.
2) Hot oil (80°):
Drive for at least 10km to let the oil heat up to normal operating temperature. Then shut the engine down, and check the level using the "hot-oil" markings.
Greetings,
renoir.
1) Cold oil (40°):
2) Hot oil (80°):
Greetings,
renoir.
