Thermostatic valve
CD's with workshop manuals, parts book and other documentation New: electronic distributor
jean-marie
Thermostatic valve
Unread post by jean-marie »
Hi ! For a Lancia 2000 ie type 820416, I search a thermostatic valve Bosch 0 280 140 026.
rogermark
Re: Thermostatic valve
Unread post by rogermark »
Hi Jean Marie
Just read your post.
You can still get new ones from Bosch but expensive. Check out http://www.partbob.com . They show basically the correct part with slight variations on the air line connections.
I have problems with the idle air valve on my 2000 coupe but I am working on a modification using modern parts.
Roger
Dino1970
Unread post by Dino1970 »
Hi,
Seeing the date of these posts you may have already solved this. Would be interested to hear how things worked out.
You can also have your auxiliary air valve refurbished at Bosch, see:
http://www.bosch-automotive-tradition.c ... man_3.html
regards
Dion
Return to “68 Flavia, Lancia 2000”
