In my '90 Thema V6 AUT the van on the coolsystems radiator decided not to turn on anymore. It seems that the van itself is ok. The garage says: it's to much work ($$) and they think there is a wire broken somewhere ..... Where is the relay situated that controls the van? Is hand-control a smart option?
thanks!!!!
maarten
van on radiator
Re: van on radiator
Unread post by Mike Schieber »
The relay is below the dashboard right below and behind the radio and ash tray. I had the same problem with my fan, and the problem was corroded contacts in the relay. I cracked open the relay and cleaned, problem solved. It was a real pain to get at the relay, Lancia puts a plastic barrier under the carpet in this area, I broke it out to get at the relay.
Hope this helps,
Mike
Hope this helps,
Mike
