Cold start problem V6
Drapu
Post by Drapu »
Hi there,
I have this problem with my Tipo 2 V6. When cold, the engine will run only when I turn up the idle. When warm, the engine will rev 1,400 when idle. When cold it will be 900 rpm. When I push the trottle (cold engine) it will nearly cut off. Only when it is warm (and after restart), the car will run smoothly (no faults on sparks or injectors). Is it the first spark cable or just the aut. choke? Anything else?
Return to “51 Thema”
