outside temp sensor location?
Gabriel Jimenez
Unread post by Gabriel Jimenez »
I have a ie 16v 1992, and my outside temp is fixed in 50ºC. when i press it, blinks for a while in 50 and the stops in 50. I thinks it needs some cleaning. can anybody tell me where can i find it in the car body?
thanks in advance
Vetle Just Kvammen
Re: outside temp sensor location?
Unread post by Vetle Just Kvammen »
It should be located behind the glas in one of your sidewive mirrors.
Andy Brice
Unread post by Andy Brice »
The outside temperature sensor for the climate control is located in the drivers side door mirror on the side nearest the window. It is visible as a small blob above the surface. You will need to dismantle the mirror to remove it.
Return to “51 Thema”
