Thema 16V LS year 1992
Andre Pieters
Unread post by Andre Pieters »
Every now and then the engine stops running, sometimes not. When it stops sometimes the failureindicator of the boardcomputer the
injection lightens up. The car is for that reason totaly unrelaiable.
Sjaak
Re: Thema 16V LS year 1992
Unread post by Sjaak »
Well, it will or might be either difficult or easy.
Most likely is the fase sensor or tdc sensor connection.
the most likely is the fase sensor. (as it just puzzles the motor management when it doesn't see this, with no oter solution than cutting out
Position is inside distributor.
Good luck.
Jeremy Ong
Unread post by Jeremy Ong »
What is fase sensor? I seem to have a similar problem. The injector light is on and no one can find the problem. I have changed the following :
1) Water Temperature sensor
2) Air flow sensor
3) Air Temperature sensor
4) Throttle Position sensor
5) knock sensor
6) idle control valve
7) ECU
8) Lamda sensor/oxygen sensor
The car runs only 0.8 bar last time can run 1.0 bar boost. The engine feels weak and consumes 2x more petrol that normal. The car is no fun to drive anymore. Please help me.
Jeremy
l.thema
Unread post by l.thema »
i don't think it's a turbo problem,did you check the timing belt?
Return to “51 Thema”
