Varistor defekt
Posted: 26 Jan 2014, 20:08
by Thesis2013
Freunde,
wenn ich nach ein paar Tagen die Zündung einschalte, kommt die Meldung "Varistor defekt", dazu erscheint ein Lenkradsymbol.
Bei warmen bzw. am selben Tag gefahrenen Wagen, kommt diese Meldung nicht mehr.
Gebe freiwillig zu, dass ich den Fehlerspeicher nicht ausgelesen habe, bisher bei den Temperaturen hält sich mein Verlangen in Grenzen...
Ist diese Fehlermeldung bekannt bzw. von "weitreichender Relevanz"?
Viele Grüße
Jens
Re: Varistor defekt
Posted: 26 Jan 2014, 20:45
by vlad47
Do you mean variosteer? There's no problem with it, only the battery level was a bit lower in these winter temperatures while starting the cold engine so there was not enough power for the variosteer and the error came out, but only till the alternator started giving the power. The variosteer is the first equipment that writes an error on low voltage, the second is the skyhook.
Re: Varistor defekt
Posted: 26 Jan 2014, 20:57
by Thesis2013
Dear Vlad,
Actually the Batterie is always in a very good state of loading, there permanently to a charging source. But maybe the low temperatures simulating a low voltage, your thesis is that this message comes just when the car did not move at least a day.
Many greetings
Jens
Re: Varistor defekt
Posted: 26 Jan 2014, 21:01
by vlad47
Yes the problem is usually there only in low temperatures, but the point is the same, you can ignore the error because there's no problem
Re: Varistor defekt
Posted: 26 Jan 2014, 21:15
by Thesis2013
OK, but what does this Variosteer?
Jens
Re: Varistor defekt
Posted: 26 Jan 2014, 21:54
by vlad47
It's the steering servo, in thesises with automatic gearbox there's a variable version called variosteer.
Re: Varistor defekt
Posted: 26 Jan 2014, 22:46
by GWB
The variable power steering is quite sensitive to the higher viscosity of the hydraulic fluid in cold temperatures and throws an error. If this happens very often and above 0 °C, I would change the fluid, otherwise I would not worry too much.
I have this phenomenon, too, and when it is below –10 °C, the pump starts making painful noises which disappear after a few seconds.
Best,
GWB
