Any one know where the ecu connection (3 way plug) to connect to Bosch tester, my Bosch dealer has been unable to locate it, ( after 9 days! and they talked to Fiat?).
I've had an intermeintt (sp) stalling/no start 3 times, after verify spark, and fuel smell, pulled and cleaned the connector on the idle control valve and car ran for several months each time.
After I thought they did a computer test/check and replaced the ign. coil. and still had no start or rough idle, they said it also needed a crank sensor, now I found out they could not find the ecu test connection.
Of course my lousy german (speaking) doesn't help, but similar parts work the same way regardless of brand.
Florida is too hot, now I live in Germany.
ecu diagnosis connection 1995 station wagon 2.0 16v
