Is anybody knows something about ABS on Lancia dedra 2.0 turbo integrale.When I start the engine everething is OK and after 10-15 sec. red light for ABS is on.When I drive car with this light off and push max break, only left rear wheel doesn`t lock.
I whould appreciate HELP!!!
Thanks!
Dedra Abs
Re: Dedra Abs
Unread post by John Purcell »
Try checking the wiring running to the speed sensor at the left rear wheel to make sure it hasn't been
damaged, chaffed/cut etc.
If the wiring is O.K. check the ABS speed sensor, it may need to be cleaned, or possibly replaced.
Unlikely that it's anything more serious than this, if luck's on your side.
