rear left door central lock doesn`t work
Danilo
Unread post by Danilo »
Hi,
I have Lancia Dedra 1.6, 1994, ABS, and it is a really GREAT car. I have a problem. My rear left door central lock sometimes work and sometimes not. For example when I press unlocking all 3 other doors open without any problme, and rear left not.Sometimes every 4 doors opens normaly.Does anybody knows what may be the problem??? Thank you in advance!!
Hugo Pinto
Re: rear left door central lock doesn`t work
Unread post by Hugo Pinto »
Hi Danilo
You just need to change the small "pump" that activates the lock. You can use a Fiat Tipo or Tempra since they are the same.
Best Regars
Hugo Pinto
Ermesinde, Portugal
Brian Hilton
Unread post by Brian Hilton »
Sorry Hugo,
On Dedra there isn't a pump, it's all electric with the motor built into the lock itself, it will probably be that the door lock itself has failed internally and will need changing, although it is worth checking the wiring in the door as sometimes this breaks.
In the UK Fiat/Lancia are running a scheme selling some Lancia parts at knockdown prices, I recently changed both rear door locks (the ones that seem to go wrong the most) and they cost me about 60% of the list price, £32 approx 44 euros each instead of £54 each instead of 74 euros each.and is much the best solution to the problem.
Regards
Brian Hilton
Dedra Advisor
Lancia Motor Club
UK
Hugo Pinto
Hi Brian,
Yes, you are correct, but this is a translation error (From Portuguese to English, not my best!! :) )
Here in Portugal we have a lot of Tipo's down the road just waiting to be pilled of :)
I found 1 that had no engine but i got all the electrics and changed my locks!!
Thanks for the correction!!!
Best Regards
Hugo Pinto
Return to “55 Dedra”
