My dedra 1.8 ie cat 93' , when external temperature goes below 7 ° centigrades , the conditioner doesn't start compressor ,so the windows are completely tarnished,specially when it rain.
Someone know how to solve this problem?
I've just replaced electronic card but it's doesn't solve this problem.
Dedra and automatic clima
Brian Hilton
Re: Dedra and automatic clima
Hi Giorgio,
When was the aircon last re -gassed, possibly it may need regassing.
If that is OK you need to start checking out fuses and relays.
Regards
Brian Hilton
Dedra Advosor
Lancia Motor Club
UK
Regards
Brian Hilton
Dedra Advosor
Lancia Motor Club
UK
Giorgio
Thank you very much Brian for your suggestions, i will check fuses and relays , and i will try to re gasser the system to solve this problem,also if the compressor start correctly when temperature are above 5-7°C.
and if i set automatic conditioner to "low" position , fresh air seems to be very good in few time.
I'm asking if could be a "tuning" about temperature setting,when compressor should be start, in the IAW 04U electronic module checkable by a lanciatester.....(??)
Mladen
Hi
I have a question by my side,
Do sambody can help my to find operation instruction to use my dedra air conditioner (klimatronic ,english language)
My dedra is 1.6 ie
Thank you in advance.
Mladen
My dedra is 1.6 ie
Mladen
