What are the correct tyre pressures for the Dedra Turbo 1992? (My handbook does not have the Turbo supplement)
Standard 15" Rims with standard 195/50 tyres.
Thanks!
Dedra Turbo tyre pressures
Dennis Radford
Re: Dedra Turbo tyre pressures
Dear Josh,
I recently fitted a new set of tyres(Pirellis) and was told by the supplier to keep them at 30 psi all round as a good compromise - seems okay.
Josh
Hmm the front tyres do look verry squashed at 30psi. I've tried 35 but makes little difference
(Continentals)
(Continentals)
Ian Wightman
The handbook supplement states measurements in bar for cold tyres and are as follows :
For average load :- front 2.4 rear 2.2 ; The equivalents in PSI are approx 35 and 32.5
For fully laden :- 2.7 2.4 39 35
Personally I use the fully laden figures all the time and find these to be fine for me . The ride quality does impair slightly (in my opinion ) mainly noticeable when in the front seats and due to the front tyre pressures .Also wet traction appears to be reduced very slightly . The sidewalls do look better though.
I experimented with higher pressures but found the result to be worse (as well as illegal , just as 30 psi for the front would be !!).
I hope this information helps you Josh , if you have not already got the figures by now.
Mick Smith
I run mine on 30psi rear 32psi front - this gives good ride quality and handling. the sidewalls look ok and the wear is ok too.
