Hello my friend,
Please kindly advice. I tried to change my brake pads and shoes today and everything seems to be working well. Handbrakes ok, front breaks ok but the brakes at the back is really weak. The result of the testing instruments were: 1) Front about 200KN, 2) Hand break about 100KN 3) back breaks about 50KN. I do not know why the back breaks are low. I have good break pads in the front and shoes at the back. I have also checked out if there is any leakage but none...what could be the problem? There is no air also in the pipes. Good bleeding has also been done. Please give me advice.
Thank you.
Ese
Low breaks at the back!!!
Julian Carter
Re: Low breaks at the back!!!
Unread post by Julian Carter »
Hi,
I think you might find that the rear brake callipers need adjusting when fitting new pads. Did you have to screw the pistons in when fitting new pads ?
Cheers
Julian
Cheers
Julian
Marian Harizanov
Unread post by Marian Harizanov »
Hi Ese... I have same problem and don't know what to do. I haven't go to service yet, but think to go... if you solve that problem pls write me a e-mail how if you can. 10x in advance for advice. i'm in Bulgaria and a I have derdra 1.6. ie. 92.
