What kind of engine does the Dedra Integrale have??
is it the same as in the Delta? and how big is the engine? how about the transmission and the suspension etc on the Dedra Integrale?
Is it possible to make a normal Dedra to be like a Dedra Integrale?
Best regards
-Nelson
Lancia Dedra Integrale
Darren
Re: Lancia Dedra Integrale
Nelson
I own a Dedra Integrale and I can tell you it has a 1998cc engine of approximately 185 bhp standard. The engine in them is a mish mash of different fiat Lancia product I am lead to beleive. It has an uprated Dedra Turbo engine which is 165 bhp, and is also the same basic engine as the normal asperated 2.0 ie/se engine. The engine is quite different from an 8v Delta Integrale engine.
Should you require any further info please e-mail me
Regards Darren
Regards Darren
Alex
Hello!!!
I also have an Dedra Integrale and former i am working for the company that develloped the 4wd-system for the delta and dedra integrale.
If you want to implement the integrale system into a usual fwd-dedra you have to modify at least:
- the floor pan to package the drive shaft, exhaust and rear axle system
- the brake-system (larger discs because of higher weight)
- different clutch design (to resist the higher torque response)
- complete suspension setting (shock absobers, springs, caster, camber.....)
Believe me, it´s senseless to try this!!!! Look out for a real integrale,
br
Alex
br
Alex
