Bought a nice Dedra engine for my delta LX got home ... looked at both engines and found out they don't share the same type of distributor.
There's a cover in the 1.6 block where the distributor is placed on my original engine. Is it possible to simply insert the distributor or is there anything different in the crankshaft ?
Marcos
Delta 1.6 SOHC - URGENT
Re: Delta 1.6 SOHC - URGENT
i think there´s no problem use the 1.6 motor whitout changes ´need to know more about the admission system of the 1.6 motor for example the gas pump in 1.6 its electrical ,debit of gas is bigger - the delta is a carburator admission 1'6 motor is injection admission maybe the electric changes
you have to make are complicated
Estou farto disto podes ver no novo post ... mas posso adiantar que até os parafusos que seguram a embraiagem ao volante do motor são diferentes
