Now you can get a olmost unbrakeball front differtial,with 50/50 al time drive and with bilt in front wicos diff,from 5 up to 35kg diff.Special differial gears olmost dubble sice and upp to about 800-1000hp strong.
special shaft, and end gear drive shaft.the drive shafts has bin tested upp to 600hp to etch axel.only speical inbilt is req,in org front diff gear haouse.if you what to get away from your front diff problems,please replay or order. price for this with all details and work,and with a complet org front diff send to me for rebilt,  3200eur. no more problems.just drive.
Janne
						Bullet prof front differital,rally and racing spec made in order.
				Guy Fawkes
Re: Bullet prof front differital,rally and racing spec made in order.
Unread post by Guy Fawkes »
thanks for leaving gibberish.
						Return to “57 Delta, Prisma, Delta Integrale”
