How can I....
Marcos Monteiro
How can I....
Post by Marcos Monteiro »
Do this ????
http://www.asalink.net/andreag/images/d ... 020911.jpg
Thanks in advance,
Marcos Monteiro
Leo Capaldi
Re: How can I....
Post by Leo Capaldi »
Err... what?
If you are wanting to install a check panel in a car which doesn't have one, you need lots of wire and the sensors and fit a switch to each door lock. The check panel tests the bulbs by being in series with the bulbs so you would need to wire from the light switch to the check panel and then to the existing bulb wires.
Best bet is to install the check panel and wire up the illumination only.
If your car has the check panel and the lights will not go out try connecting a new earth connection to it - connect it to one of the black wires.
Good luck, Leo
Marcos Monteiro
Re: How can I....
No Leo,
The car already has a check panel the thing is the installation of Thema's A/C control on a Delta
Thanks in advance,
Marcos
Leo Capaldi
Re: How can I....
Ah -oops I didn't spot the air-con bit!
My opinion is that it would be un-viable to do this mod. The servo units that are used are not designed to work with the Delta heater unit, and the Thema heater would not fit into the Delta. Anyway, my experience of the Thema unit is that it is difficult to get "good" settings with it ie to have some air to the screen and to the cabin at the same time, so I suggest that you stick with the Delta setup and if you want air-con then try to find the parts from an integrale, or possibly a Prisma - some had the auto climate control.
Leo
Return to “57 Delta, Prisma, Delta Integrale”
