Just restored a '89 Prisma 1.6 ie and would like to change its fluids. Will appreciate the following information:
Manual transmission oil type and capacity
Differential oil type and capacity
Engine oil type and capacity
Coolant type and capacity
Thanks!
Fred
Help needed: Fluid type/volume info. for Prisma 1.6 ie
Marc
Hello Fred
The transmission and diff. is at one piece so it means 1,4 litre of Tutela ZC 80S.
For the engine total capacity 4,25 litre but for oil change only 3,75 of Selenia SAE 15W/40.
Coolant type is Fiat Paraflu fluid total capacity is 4,9 litre.
Check your dipsticks (transmission-and engineoil) for the right capacity!
Vincent Vedder
Re: Help needed: Fluid type/volume info. for Prisma 1.6 ie
You already have an answer to your question, but I had a Prisma some time ago (I wrecked it...) and I still have the Instructions Manual. You can Have it if you want.
Greetings Vincent.
Greetings Vincent.
