S1 Gearbox 4 speed problem - Third gear jump
Huib
Site Admin
Re: S1 Gearbox 4 speed problem - Third gear jump
Unread post by Huib »
Of course the selector parts on the outside have to be checked and fixed. Don't give up on the slider too soon!!! Everything overlooked on the inside is heavily punished as the thing has to be taken apart again.
The story is that the job of the navigator of Sandro Munari was to hold the gear in 3rd (in the days of the 1.2HF and 1.3HF). On the 1.6HF Lancia put a short stick which was mounted upright.
In the parts book I have I see that the slider for 3 and 4 comes from the 815.000 which is the first Flavia. That one has column shift. The problem does not occur on the cars with column shift. There is no long stick hanging from the mechanism under an angle. It is very well possible that early sliders did not have the back cut on the teeth inside the slider for the 3rd. I recommend to actually check the teeth for the 3rd for the back cut on all the teeth. To the untrained eye it looks like wear. If in doubt, buy a new slider. Same for the springs and balls inside the sliders and the fork mechanisms. They are available at acceptable cost.
Did you replace the bronze bushes for the yoke at the top? Don't forget those. Are the forks straight? Are all the clearances indicated in the book correct?
On the outside, do everything. If you really really want a perfectly shifting gearbox also put bronze bushes in the aluminium piece holding the small shaft with the hammer at the yoke end. The yoke has two wings at the top which function as anvils for the hammer at the end of the shaft. They often have one or two dents. Fill them by welding steel on them and grind them for minimal clearance with the hammer.
lancia7550
Unread post by lancia7550 »
Thanks for all the advice Huib and fellow forum users. I am glad to report all my gearbox issues seem to be resolved:
After a few hundred kms no oil leaks visible: I replaced the two front seals and the sideshaft seals, as well as all the gaskets. I put some sealer on the surface inside the half shafts where the nut seats. Also replaced the small oil seal inside the speedo drive - see attached - that has clearly never been replaced!
3d gear stays in place now when the clutch is pushed in:
The 3-4 slider was on inspection installed correctly. So I put a small shim in with the ball and spring in the inner selector mechanism and tightened everything on the outside mechanism up to the point just before it restricts movement. Clicks in and out of third with a nice "click" now.
Best of all, my second gear downsift issue is fixed! Have been nursing that for 10 years... The syncro was basically brand new, but has clearly not been lapped when installed by a gearbox shop previously. From the shiny and dull marks in attached picture you can see the inside of the syncro ring did not fully make contact with the cone. After lapping with grinding paste for about 30 second the "grip" on the cone drastically increased. There is now no delay or grinding when shifting (down or up) into second, even when cold!
Huib
Site Admin
Thanks for the feed back.
khrell
Unread post by khrell »
I'm very glad that this thread is helping more people. Today I finished turning the 3rd gear selector pinion and installed new synchronizers.
Now I have another doubt when assembling, I have seen that I am missing some cotter pins on one side of the gearbox output (I put a photo from a magazine where you can see the assembly)
I don't remember that they were in the first disassembly and I don't know if it is possible to get them 😔
Huib
Site Admin
Oops. You absolutely need 3 in each flange. Loosing one is normal when you dismantle a Lancia gearbox for the first few times. What you can do is follow the system of the series 2. Use circlips:
Nice book. Which book is that?
khrell
Thank you for your answers Huib. I finally got the original keys and they are now in place.
Now I'm a bit desperate, I've assembled the box (without putting the transmissions together yet) :evil: , I've tried to put the gears in when stationary and all of them go in except 1st and 2nd. This shifter has new first gear pinion and the two synchronisers.
Neutral, 3rd, 4th and reverse are all perfect. I don't know if it's because we haven't fitted something right on the 1st and 2nd gear shifter or if it could be something simpler: like the synchronisers haven't been aligned properly... I don't know, I'm worried that I'll have to open the box again :( . We tried shifting everything before assembly and it was fine.
P.S: What you can see in the photo are French Gazoline magazines, where in several issues you can see how they repaired a box identical to mine and I used it as a reference. I scanned everything and made a manual, I'll look for it and share it.
Thank you!
georges2
Unread post by georges2 »
Hello everybody
I am really interested by the discussion below
A few weeks ago I had some trouble with my clutch, (Fulvia 13 S) as it was impossible to select any gear when engine running
This problem disappeared last sunday, I dont know why
This gave me the idea to change gear oil, and try to find the Millers oil CRX75W90NT+
As I live in Dordogne, sellers are quite rare, but fortunatly, I discover a shop not so far
But they give me an advert about this category of oil, which could occur some trouble due to bronze metal, (drain plugs, and may be some other parts ?). They say it would be better use Millers Classique 80w90 GL4 c
I feel and drive rather as a cool driver...
Best regards; Georges2
Huib
Site Admin
The Millers CRX75W90NT+ should not give a problem for the yellow materials. These stories are usually from the very early days of synthetic oil over half a century ago.
Note that there is also the CRX75W140NT+. If you drive wearing a cap, use the 90. If you wear a hat, use the 140.
khrell
After finishing the box and connecting it to the car, it works wonderfully. I put the oil recommended by Huib and it's going very well.
The marches enter well, but sometimes it's hard for me to find their place. I have checked the lever mechanism and I only see two things that I can adjust, the bar with two "balls" one at each end (I can play with its length) and the other thing I can adjust is where the gear lever itself is inserted, making it more or less hard, any idea?
Huib
Site Admin
Strictly between you and me, there is no gearbox in the world which comes close to the brilliant shifting of the 4 speed Fulvia and Flavia gearboxes with the stick shift. The long stick which goes almost straight into the gearbox. It is called leva lunga in Italian.
Because the stick is very long, a minimum play at the bottom results in a lot of play at the top. After a few 100.000 km there is some play on most of the linkage parts at the bottom. If you really want to experience the superb switching you have to take the parts to a machine shop. And also change the bronze bushes for the yoke. Check and weld also the two wings at the top of the yoke. Same for the hammer which operates on the yoke at the end of the shift shaft. It is worth it.
Return to “65 Fulvia”
