what rims for my S 1 ?
Geoff
Re: what rims for my S 1 ?
Unread post by Geoff »
as has Mr. Fiat.
Geoff Goldberg
1952 B20 s.2
1957 B24 s.6
1959 Appia Berlina s.2
Ed Levin
Unread post by Ed Levin »
It doesn't seem sensible to buy wheels from Italy by way of the US. That US seller doesn't stock any wheels; you pay him and he orders from Italy. You pay for shipping from Italy to him and from him to you. It would make more sense to buy from Italy, as here:
http://www.ricambirossocorsa.it/it/174- ... o-storiche
georges2
Unread post by georges2 »
Thanks for this information; I did not know this seller, of course it's better to shorten the "network"...
Nice drives to you all, and kind regards
khrell
Unread post by khrell »
Huib wrote: 06 Aug 2011, 10:28 The S1 (any in fact) Fulvia runs best on the original steel wheels with the original tyre size. Bridgestone makes an excellent 145/80R14 tire. It has to be inflated to a somewhat higher than usual pressure. I use 2.2 to 2.4 bar.
If you insist on changing to 13" rims you can use 165/80R13 tyres. Plenty of good tyres are available in this size. The circumference is the same as for the 145R14.
With some types of the 13" wheels you will have interference with the brake callipers and the pincher of the handbrake. This can be solved by grinding some off the callipers. Also make sure there is clearance between the brake lines and the wheels.
At the rear you will also have interference with the wheel arches. When you use the Stilauto 5,5J13 wheels with 165/80R13 tyres you have to extend the rubber stop over the rear axle by 45 mm. I also advise stronger rear springs. With the standard springs the rear axle will hit the stop all the time which shortens the life time of mechanical parts such as the wheel bearings and body. If you use 6J13 wheels, you will have to extend the rubber stop even more.
Sorry for bringing this topic up again after several years. I've put 13" Stilauto rims on my Fulvia S1, the same ones Huib mentions. I've only noticed some rubbing when I'm driving on the highway at high speeds and encounter a sudden change in the road surface.
I've removed the rim and don't see any internal rubbing due to the brake calipers. I've removed the rubber buffers with the intention of lengthening them, as Huib mentions, but the nut that holds it inside the trunk is flush with the sheet metal. If I add rubber to lengthen it, I won't be able to hold it in place.
any ideas?
Return to “65 Fulvia”
