has anyone experience with offset camberbolts to replace the normal M10 bolts fixing the front strut to the hubcarrrier? These bolts looke like small camshafts were the lobes accomodate a different position between the carrier and the strut. In this case move the upper part of the carrier closer to the strut creating negative camber. For popular cars like VW's these bolt are readily available.
I'm fitting bilstein lower springs and want (mostly for the looks as the roadholding leaves little to be disired as is) the wheels to tuck in on the up side.
beta negative camber
Return to “61 Beta, Beta spider, Beta Zagato, Trevi”
