Beta Flasher unit
CD's with workshop manuals, parts book and other documentation
John Thorpe
Beta Flasher unit
Unread post by John Thorpe »
The 6 pin flasher unit on my 1981 Beta sedan needs to be replaced, Does anyone know if there is a currently availabe unit from Hella etc that will fit as the Isola ones are proving very ahrd to come by.
leo capaldi
Re: Beta Flasher unit
Unread post by leo capaldi »
Hello John,
I can't offer much but... First of all try Chad at the Monte Hospital, he has a lot of good contacts. The Montecarlo flasher unit is only a 3 pin thing though.
I cannot find a six pin flasher on the diagrams for the Beta sedan in the Haynes manual. Is it the 5 pin (connector looks like 6 ) one for the hazard flashers? As far as I can see there is also a 3 pin unit for the "turn" signals. I have to confess that I do not know what my S3 HPE has!
If you can tell me the pin connections I will work out what you can do in the way of alternatives.
Leo
John Thorpe
Thanks for your offer to trace the wiring - but I've found the solution. Beta Cars was able to source a fix it kit made by Lancia. This plugs into the socket where the flasher wouod normallly go. It is a bit of wiring loom and an electrical box about the size of the old flasher into which plugs a normal 3 pin flasher can. It all worked perfectly first time. Much easier than trying to redo the wiring.
leo capaldi
Wow!
Good old Betacar. I looked more closely at the diagram and the hazard switch is quite different from "traditional" ones - fewer contacts so the electronics box must compensate by having diodes in it. Would be interesting to know what is in there!
Leo
Return to “61 Beta, Beta spider, Beta Zagato, Trevi”
