Aldo Broverone's Opinion on Fulvia Sport
CD's with documentationElectronic distributor
racing
Re: Aldo Broverone's Opinion on Fulvia Sport
Unread post by racing »
After a break depent on some other requested work in our home by my wife i
go forward step by step with the project.
Have to clean the front alu skin to be able to repair later the destroyed sections.
saluti
Andreas
racing
also done in the meanwhile :
The cage
i think it look´s good.
Andreas
fulvia a.i.
Unread post by fulvia a.i. »
I want won two !
racing
After cleaning the front maske i have checked if it fit depent on the new steel sheet´s on at the front.
My son welded partial the alu sheet´s on the side of the fender. ( not so easy >:D< )
regards Andreas
racing
I am still in process. Some pic´s enclose.
Regards Andreas
racing
the front is back :)-D
zagato bodypaint.jpg (68.46 KiB) Viewed 640 times
racing
several works / decisions to do / done.
regards Andreas
wishbone singel parts .jpg (62.9 KiB) Viewed 640 times
choice 4_5 speedgearbox.jpg (29.85 KiB) Viewed 640 times
fulvia a.i.
the front is back ! Great !
For some weeks U was sure you had put this labor-a-luv on a back-burner for 2011
as always, maybe I',m amazed,,,,,,,,,,,,,,
racing
Yes, it was possible to speed up a little bit.
Enclose the check of the doors inside the body before build up the doorskin.
Will try to make new one´s :S
Some adjustments were necessary.( with a big hammer ;) ) and add. the tube to give the door a bit more stiffness
Before it was like a sheet of paper
but i believe it look´s good and fit ( more or less )
Regards Andreas
racing
some add. pic. from the work on the weekend.
Check of the bonnet. Fit´s
New skin of the door, one side. Hmmm. Not so bad but not finished.
Regards Andreas
Return to “65 Fulvia”
