Counting Gears
CD's with documentationElectronic distributor
ekranoplan
Counting Gears
Unread post by ekranoplan »
I am taking apart a S2 5 speed gearbox (it has no blue ID plate). The Final Drive / Pinion is marked with the ratio 11/43.
Is there a way to work out all the ratios by counting the gears?
Rear to Engine end of box:
Layshaft: 35, 32, 28, 22, 15
Pinion: 23, 27, 33, 39, 41
Cheers
ekranoplan
Re: Counting Gears
worked it out!
It's a Coupe 1.3 S2 gear box
Return to “65 Fulvia”
