I have just purchased a nice new set of Koni shocks for the Fulvia rebuild. As these need to be adjusted prior to fitting, can anybody using these recommend the optimum settings for use on a S2 Fulvia coupe. The car will be driven enthuastically as a fast road with the odd long distance run.
Many Thanks
Julian
Koni shocks
Paul de Raymond Leclercq
Re: Koni shocks
Unread post by Paul de Raymond Leclercq »
If these are Koni "Classics" then they should not be adjusted; I understand that the adjustment is intended to accomodate wear.
The yellow-finished Koni "Sports" are intended to be adjusted.
If you do want to adjust them anyway, I suggest about +1/3 at the front and as supplied at the back
Paul
Paul
