I have a Lybra 1.8 SW 2000 mod. I love the car and it works well as long as I give it some TLC.
Problem these days is that I suspect that the drain pipe from the A/C system is blocked. The reason is that I have a "mist problem" on wet days, and I can't see any or just samll amounts of water comming out under the car. In addition the smell is not exactly like roses either....
I have tried to find the drain pipe in order to run a A/C cleanout, but I am not sure were it ends. Looks like it is behind the steering rack. I can see 2 aluminium pipes comming through the torpedo wall, but which one is the drain pipe ? A solution could perhaps be to cut the pipe and connect a rubber hose that could be led out through the lower engine cover?? This way the drainage could more easily bee looked after.
Anyone else who have had this problem ? Any suggestions how to deal with the problem ?
I have also read that the Alfa 156 has a potential rust problem in the floor caused by overflood in the AC system, and I do not want this to happen with my Lybra.
Brgds form Norway
