g/box exploded !
justin
g/box exploded !
Post by justin »
Hi
Anyone got a Kappa 20vt 5-spd gearbox they want to sell?
This, I have found, is NOT the same as a Fiat coupe 20vt 5-spd box.
The cable controls are different, and the Kappa 20v 2.4 rod controls are not interchangeable with the box I need.
I may have to go over to a rod control system but that would mean using the 20v 2.4 ratios, which are also different !
It's not even as if I was really going for it, but the torque available from the 20VT is clearly beyond the capability of this box - the diff exploded into the bell housing!
I have heard similar tales so I must remember to be more careful next time.
Looking at the hole inside the b/housing doesn't show much scope for strengthening, but I have been told that there is a pin holding the diff together that can become displaced due to the feeble system retaining it, so maybe this is the weak link.
Anyone ?
Jus
Lindsay
Re: g/box exploded !
Post by Lindsay »
Hi Justin. Not good. Surprising the Fiat box is different. No wonder they dont make money. Might be worth asking trevor in the LMC. He races a Kappa saloon and has 2 breakers - but i think they are both autos.
Go to the LMC forum and stick someting on the Kappa section.
Cant see anyone else in the UK having a spare box but you never know. Try looking on ebay.it as well. Shipping may be hefty but more likely to find one.
Best of luck.
Lindsay
Karsten
Post by Karsten »
Auch!!! How many miles/kilometers before the gearbox "exploded"?
Have you often been pushing it to the limit?
trc
Post by trc »
bad story.
i lost 5 gear on my 2,4 k recently so if you find a place where can buy gearbox or part s for it then as usual eny help is good.
tnx
justin
Post by justin »
About 230kkms, so a good innings.
I've heard that the Fiat 20VT Coupe has 3 variants of gear linkage, none of them the same as the Kappa !
What were Fiat thinking ?
Jus
justin
Post by justin »
I'm back online - hurrah!
Still no replacement g/box but I have it on good authority that L&M might be able to help.
When I've can release a bit of budget I'll speak to them.
What I have found for sure(?) is that the Fiat Coupe 20vT had the same box in the later days, but the early K 20vT had a nicer selector action using a more costly mechanism.
Classic Lancia over-engineering for detail improvements, only to be later cheapened to Fiat levels.
I have one of the later Fiat Coupe 20vT 5-sp boxes going if anyone's interested; I must get the Kappa back very soon - I'm going spare driving a Punto and a VW Sharan (albeit a VR6), and missing the Lancia desperately!
Regds,
Jus
Return to “47 Kappa”
