new owner - fulvia s1
CD's with documentationElectronic distributor
Huib
Site Admin
Re: new owner - fulvia s1
Unread post by Huib »
Here you can see the special tool to stretch the leave spring when mounting. Without the tool the shackle will flip forward and the car will be extremely tail high.
Als I noticed that the reflectors on the tail are mounted wrong way.
tag89
Unread post by tag89 »
That looks like a job that might require a trip to Breda ;D I've done quite a few coil springs in my time but wouldn't know where start with a leaf.
And re: reflectors...wrong way?
Huib
Site Admin
The rear is concave. The thicker side of the reflectors should face inward.
tag89
ah I See, yes that would make sense so you geta more 'square on'view of the reflectors. a nice easy change!
Huib
Site Admin
It means also that the person who worked on the car, did not know the car. There might be many "booby traps".
tag89
may also explain why the suspension is about as high as my defender :D
Huib
Site Admin
You can sell the Defender. If the Fulvia is ok you will not think about the Defender anymore.
Old Sparky
Unread post by Old Sparky »
No idea if any help at this point but here goes.
I have a 1969 S1 Fulvia Coupe which was too low. Omicron have fitted correct springs as it turned out it had a set of specials from UK maker which lowered it. I have these in garage if you want them as I will never use them - car is for rallying and height is important.
Regards
Old Sparky
tag89
Old Sparky wrote: 21 Apr 2025, 21:01 No idea if any help at this point but here goes.
Regards
Old Sparky
Sent you a private message, thanks
Fire3500
Unread post by Fire3500 »
@huib your first reply is poetry!
1968 Series 1 Fulvia 1.3 Rallye
Return to “65 Fulvia”
