Magnesium-Klappe bleibt nicht zu
Benedict09
Bei meinem Thesis bleibt die Magnesium-Klappe in der Mittelkonsole nicht mehr zu.
Habe das auch schon bei dem ein oder anderen Thesis auf den üblichen Verkaufsplattformen gesehen.
Weiß hier jemand, wie man das wieder beheben kann?
Vielen Dank im Voraus
Klaus
Klaus
Pierre VALLADE
Re: Magnesium-Klappe bleibt nicht zu
This is a problem for many Thesis. There is a small plastic clip that keeps the shutter closed. Often by removing the front of the console, the clip falls and you do not notice it. Hopefully the clip fell into the console, there it is enough to put it back. Otherwise, I don't know of a solution.
Pierre.
Pierre.
Benedict09
Hi Pierre,
thanks for your tip.
It worked when I bought the car. Since then the console was not removed. The pin is still in place, I can see it when I try to close.
Kind regards
Klaus
Kind regards
Klaus
Pierre VALLADE
Hello Klaus,
Maybe the clip is not in the right position. On my Thésis, by removing the front of the console, I found the clip which had fallen and the shutter had not closed for several years. I put it back in its place and since the shutter closes properly. Not very important, but I am happy of course.
Best regards.
Pierre
Best regards.
Pierre
Benedict09
Hi Pierre,
It is worth a try.
Can you please tell me how to remove the front of the console?
Kind regards
Klaus
It is worth a try.
Kind regards
Klaus
Pierre VALLADE
Hi,
Not very difficult but of course need to be carefull.
Below a link to the Lancia Thesis Club de France with a video showing how to remove the NIT Connect. You just need to execute the beginning of the procedure, except if you want to remove the complete NIT.
In few words.
There are six screws to remove, you just need a usual screw driver.
Extract the piece of "wood" at the top of the dashboad (running from the left to the right sides), no tool : just taking it of. Need attention, but easy to do
Then, you wiil see the two screws at the top of the facade
Open the ashtray, remove the two screws fixing the ashtray. Then you will discover the two other screws fixing the facade at the bottom.
There are two connectors behind the facade (a black and a blue one). Then the facade will be free.
Sorry for my poor english language.
Feel free to contact me through PM.
http://www.lanciathesis-clubdefrance.fr ... t-astuces/
Best regatds,
Pierre
In few words.
Best regatds,
Pierre
Benedict09
Hi Pierre,
regarding your English I would say we meet on the same Level 😏
Thanks for your description and the video, this was very helpfull. As I thought before, the clip itself is still in place, but the small nipple on the clip, that in the end keeps the shutter closed, is broken. A spare part, worth a few Cents, but I bet It will be hard to get.
Did anyone tried to get this before?
Again, thank you Pierre, France, douze points 😀
Nochmal an alle, die nicht so gerne Englisch lesen. Es geht bei der Magnesium-Klappe um einen gebrochenen Nippel an dem weißen Clip oben in der Mitte der Klappe. Weiß jemand, ob man diesen Clip evtl. als Ersatzteil über Fiat beziehen kann?
Vielen Dank und viele Grüße
Klaus
Klaus
vor ein paar Jahren gab es das Teil für 4 Euro beim Händler. Ob das heute noch geht, weiss ich allerdings nicht.
Viele Grüße
Andreas
Viele Grüße
Andreas
Guten Abend,
der hier im Forum registrierte und allseits geschätzte Thesis-Spezialist Vlad47 hat diesen Teil soweit ich weiß selbst nachproduziert und bietet ihn auch zum Verkauf an. Er ist auch über fb zu erreichen: Lancia Thesis eu.
Beste Grüße und frohe Ostern!
Austriaci
Austriaci
Benedict09
Danke für Eure Tipps Thor242 und Austriaci.
Na, das nenne ich mal ein internationales Forum:
Problem in 🇩🇪 Deutschland
Diagnosehilfe aus 🇫🇷 Frankreich
Tipp zur möglichen Lösung aus 🇦🇹 Österreich und
vielleicht die Lösung aus der 🇸🇰 Slowakei
Ich habe Vladimir mal angeschrieben...
Viele Grüße
Klaus
Viele Grüße
Klaus
