Intermittent tachometer 1974 S2 / Shift Knob replacement
CD's with documentationElectronic distributor
lancie
Unread post by lancie »
hi all - new to this car -
1) car is in generally great shape but the tachometer "hangs out" around 3500 RPMs when I'm just driving down the road - it'll start moving if I really step on the accelerator of if I am at a stop - is the best way to do this to rebuild the tachometer?
2) cannot seem to find the HF shift knob anywhere - does anyone have a source? Also, when I turn my knob, the entire shaft spins - is this normal? How does one replace the shift knob?
Thank you!!
Huib
Site Admin
Re: Intermittent tachometer 1974 S2 / Shift Knob replacement
Unread post by Huib »
About the tachometer. I posted on this before. Search this forum on "schematic" and you will get there.
lancie
Huib wrote: 15 Jul 2020, 10:43 About the tachometer. I posted on this before. Search this forum on "schematic" and you will get there.
Thanks - unfortunately I am not able to really understand the schematic due to my limited electronics knowledge. Can you simplify the issue for me? Does the tachometer need to be rebuilt? Thanks a lot.
Huib
Site Admin
Is the instrument made by Veglia Borletti or Jaeger?
lancie
Huib wrote: 16 Jul 2020, 21:24 Is the instrument made by Veglia Borletti or Jaeger?
Veglia - thank you.
Huib
Site Admin
In that case the circuit diagram of the electronics which I made and published applies.
The input resistor should be checked and possibly replaced. You will have to find someone who understands electronics and can read the color codes.
lancie
Huib wrote: 16 Jul 2020, 21:57 In that case the circuit diagram of the electronics which I made and published applies.
Thanks - are there any reputable sources to have this done by a specialist?
Return to “65 Fulvia”
