I have found a set of Eibach springs from an Alfa 164 which is identical to the Themas.
How do I go about disconnecting the existing electronic dampers in order to remove them and try these Eiback springs out?
Deon
Thema Series II - electronic dampers
Re: Thema Series II - electronic dampers
Unread post by agus »
hi Deon ,
there is nothing special you should do. just remove them, cut the wires and install new dampers,
you can also unplug the main fuses of the electronic suspension at trunk, thats what I did
regards
regards
Unread post by smokeme »
There's a connector on each electronic damper to disconnect it, remove fuses to disable the red fault light on the dash..
- ↳ D11 Ypsilon 2024
