Remove air ventilation box
CD's with documentationElectronic distributor
ThomasW
Unread post by ThomasW »
Hello, Does anybody know the way to remove the air venitlation box mounted in the rear of engine bay against the bulkhead? There are two rubber plugs in it, I would think they give access to mounting screw but havn't figured it out yet.. I have a S3 from '74, not sure if that matters.. Thanks!
Huib
Site Admin
Re: Remove air ventilation box
Unread post by Huib »
Remove the rubber plugs. You need a 1/4" socket set. Put socket 10 on an extension and stick through the hole.
ThomasW
Ok, thanks! I'll have to take a closer look then..
Return to “65 Fulvia”
